Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Remove all cables plugged into the PlayStation.
  • Remove all cables plugged into the PlayStation.
Aggiungi Commento
Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
  • Flip over the PlayStation and remove the six screws from the bottom.
Aggiungi Commento
Flip the PlayStation back.
  • Flip the PlayStation back.
  • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
Aggiungi Commento
Lift up and remove the upper case. Lift up and remove the upper case.
  • Lift up and remove the upper case.
Aggiungi Commento
Disconnect the ribbon cable and wired cable connectors. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
  • Disconnect the ribbon cable and wired cable connectors.
  • Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
trickster
Membro da: 23/12/2013
1.857 Reputazione
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 2,790
