Introduzione
This will guide you through the process of replacing your logic board.
Parti
Nessuna parte richiesta.
Remove the parallel port cover on the back of the PlayStation.
  • Remove the parallel port cover on the back of the PlayStation.
The SCPH-9001 model does not have the Parallel Port panel to remove.
Aislinn - Replica
Flip over the PlayStation and remove the six screws from the bottom.
  • Flip over the PlayStation and remove the six screws from the bottom.
Aggiungi Commento
Turn the PlayStation upright. Remove the cover by lifting it up.
  • Turn the PlayStation upright. Remove the cover by lifting it up.
Aggiungi Commento
Carefully disconnect the gold-colored ribbon cable from it's connector.
  • Carefully disconnect the gold-colored ribbon cable from it's connector.
  • To avoid damaging the cable, pull it by the white, reinforced tab.
Aggiungi Commento
Disconnect the second cable by pulling up on the plastic connector at the end.
  • Disconnect the second cable by pulling up on the plastic connector at the end.
While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
Zvezdan Disic - Replica
Do I solder it or what?
Lift the optical drive off of the PlayStation.
  • Lift the optical drive off of the PlayStation.
Aggiungi Commento
Remove the four screws from the logic board's metal cover.
  • Remove the four screws from the logic board's metal cover.
Aggiungi Commento
Detach power supply connector from logic board by pulling on the plastic tab.
  • Detach power supply connector from logic board by pulling on the plastic tab.
Aggiungi Commento
Detach white ribbon cable from logic board by gently lifting on it.
  • Detach white ribbon cable from logic board by gently lifting on it.
Aggiungi Commento
With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
  • With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
  • With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
Aggiungi Commento
Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
  • Using the same process from the previous step, wedge the spudger between the clamps and metal cover on the bottom side (as shown in the picture).
  • With your other hand, pull up on the top right corner of the metal cover to lift it off.
Aggiungi Commento
Remove the last four screws from the logic board.
  • Remove the last four screws from the logic board.
Aggiungi Commento
Lift the logic board out of the PlayStation and replace with a new logic board.
  • Lift the logic board out of the PlayStation and replace with a new logic board.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
JakeDeschamps
Membro da: 28/10/2009
945 Reputazione
6 Guide realizzate
Cal Poly, Team 5-2, Regan Fall 2009 Membro di Cal Poly, Team 5-2, Regan Fall 2009
CPSU-REGAN-F09S5G2
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 118
Tutti i Tempi: 16,784
