Salta al contenuto principale
PlayStation 3 Slim Control Board Replacement
Cosa ti serve
  1. PlayStation 3 Slim Control Board Replacement, Top Cover: passo 1, immagine 1 di 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Control Board Replacement: passo 2, immagine 1 di 2 PlayStation 3 Slim Control Board Replacement: passo 2, immagine 2 di 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Control Board Replacement: passo 3, immagine 1 di 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Control Board Replacement: passo 4, immagine 1 di 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Control Board Replacement: passo 5, immagine 1 di 2 PlayStation 3 Slim Control Board Replacement: passo 5, immagine 2 di 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Control Board Replacement, Control Board: passo 6, immagine 1 di 2 PlayStation 3 Slim Control Board Replacement, Control Board: passo 6, immagine 2 di 2
    • Use the tip of a spudger to pry the control board out of its housing within the lower case.
    • Pull the control board ribbon cable away from its socket on the control board.
Conclusione
Altre 21 persone hanno completato questa guida.
2 Commenti
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
wrestlemaniafreak - Replica
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 151
Tutti i Tempi: 26,873
