Introduzione
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
Please SUBSCRIBE to my channel ツ
More info about disassembling, you can find in
PlayStation 3 Slim Teardown
Panoramica Video
Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
Aggiungi Commento
Remove Power Supply. Remove Power Supply. Remove Power Supply.
  • Remove Power Supply.
Aggiungi Commento
Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive.
  • Separate cables, unscrew the screw and remove the Blu Ray drive.
Aggiungi Commento
Disassemble the upper metal shield. . Please SUBSCRIBE to my channel  ツ
Aggiungi Commento
Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles.
  • Remove the two very small phillips screws in each lower corner referenced by the red circles.
Aggiungi Commento
Be careful with flex cables. Be careful with flex cables. Be careful with flex cables.
  • Be careful with flex cables.
Aggiungi Commento
Now you can remove the Laser Deck. Now you can remove the Laser Deck. Now you can remove the Laser Deck.
  • Now you can remove the Laser Deck.
Aggiungi Commento
Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers.
  • Transfer two flex cables and 2x rubbers.
Aggiungi Commento
You can test the console before full assembling. . Did you do it successfully?
Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
150.367 Reputazione
424 Guide realizzate
Master Techs Membro di Master Techs
Community
274 Membri
713 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 128
Tutti i Tempi: 14,134
