Salta al contenuto principale
PlayStation 3 Lower Case Replacement
Cosa ti serve
  1. PlayStation 3 Lower Case Replacement, Smart Plate: passo 1, immagine 1 di 2 PlayStation 3 Lower Case Replacement, Smart Plate: passo 1, immagine 2 di 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Lower Case Replacement: passo 2, immagine 1 di 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Lower Case Replacement: passo 3, immagine 1 di 3 PlayStation 3 Lower Case Replacement: passo 3, immagine 2 di 3 PlayStation 3 Lower Case Replacement: passo 3, immagine 3 di 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Lower Case Replacement: passo 4, immagine 1 di 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Lower Case Replacement, Top Cover: passo 5, immagine 1 di 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Lower Case Replacement: passo 6, immagine 1 di 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Lower Case Replacement, Blu-ray Disc Drive: passo 7, immagine 1 di 1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Lower Case Replacement: passo 8, immagine 1 di 1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Lower Case Replacement: passo 9, immagine 1 di 3 PlayStation 3 Lower Case Replacement: passo 9, immagine 2 di 3 PlayStation 3 Lower Case Replacement: passo 9, immagine 3 di 3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 Lower Case Replacement, Motherboard Assembly: passo 10, immagine 1 di 1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 Lower Case Replacement: passo 11, immagine 1 di 2 PlayStation 3 Lower Case Replacement: passo 11, immagine 2 di 2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 Lower Case Replacement: passo 12, immagine 1 di 1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 Lower Case Replacement: passo 13, immagine 1 di 1
    • Remove the control board bracket.
  14. PlayStation 3 Lower Case Replacement: passo 14, immagine 1 di 2 PlayStation 3 Lower Case Replacement: passo 14, immagine 2 di 2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 Lower Case Replacement: passo 15, immagine 1 di 1
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 Lower Case Replacement, Lower Case: passo 16, immagine 1 di 1
    • Lower case remains.
Conclusione
Altre 12 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 51
Tutti i Tempi: 17,945
