Salta al contenuto principale
PlayStation 3 Control Board Replacement
Cosa ti serve
  1. PlayStation 3 Control Board Replacement, Smart Plate: passo 1, immagine 1 di 2 PlayStation 3 Control Board Replacement, Smart Plate: passo 1, immagine 2 di 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Control Board Replacement: passo 2, immagine 1 di 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Control Board Replacement: passo 3, immagine 1 di 3 PlayStation 3 Control Board Replacement: passo 3, immagine 2 di 3 PlayStation 3 Control Board Replacement: passo 3, immagine 3 di 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Control Board Replacement: passo 4, immagine 1 di 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Control Board Replacement, Top Cover: passo 5, immagine 1 di 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Control Board Replacement: passo 6, immagine 1 di 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Control Board Replacement, Control Board: passo 7, immagine 1 di 2 PlayStation 3 Control Board Replacement, Control Board: passo 7, immagine 2 di 2
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. PlayStation 3 Control Board Replacement: passo 8, immagine 1 di 1
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. PlayStation 3 Control Board Replacement: passo 9, immagine 1 di 1
    • Remove the control board from the lower case.
Conclusione
Altre 17 persone hanno completato questa guida.
2 Commenti
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - Replica
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 113
Tutti i Tempi: 49,561
