Disconnect all cables from the console and flip the unit over to reveal its base.
  • Disconnect all cables from the console and flip the unit over to reveal its base.
Aggiungi Commento
Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws. Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony. Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
  • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
Aggiungi Commento
Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver. Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver. Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
Aggiungi Commento
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit. Note: You may use your hands for additional force to separate the two pieces of the outer shell. Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
  • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Aggiungi Commento
Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard. Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
Aggiungi Commento
Remove the four 4.0 mm screws using a #1 Phillips screwdriver. Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
Aggiungi Commento
Locate the three ribbon cables connecting the optical drive to the motherboard.
  • Locate the three ribbon cables connecting the optical drive to the motherboard.
Aggiungi Commento
Gently detach the ribbon cables from the motherboard using a pair of tweezers. Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable. Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
  • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
  • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
Aggiungi Commento
Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive. Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive. Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
  • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
Thomas Sullivan
Membro da: 23/10/2013
2.114 Reputazione
6 Guide realizzate
انا أريد للغة عربية
Muammar lmgaroush - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 72
Tutti i Tempi: 5,639
