Salta al contenuto principale
PlayStation 2 Slimline Fan Replacement
Cosa ti serve
  1. PlayStation 2 Slimline Fan Replacement, Outer Shell: passo 1, immagine 1 di 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Fan Replacement: passo 2, immagine 1 di 3 PlayStation 2 Slimline Fan Replacement: passo 2, immagine 2 di 3 PlayStation 2 Slimline Fan Replacement: passo 2, immagine 3 di 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Fan Replacement: passo 3, immagine 1 di 3 PlayStation 2 Slimline Fan Replacement: passo 3, immagine 2 di 3 PlayStation 2 Slimline Fan Replacement: passo 3, immagine 3 di 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Fan Replacement: passo 4, immagine 1 di 3 PlayStation 2 Slimline Fan Replacement: passo 4, immagine 2 di 3 PlayStation 2 Slimline Fan Replacement: passo 4, immagine 3 di 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Fan Replacement, Fan: passo 5, immagine 1 di 2 PlayStation 2 Slimline Fan Replacement, Fan: passo 5, immagine 2 di 2
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Fan Replacement: passo 6, immagine 1 di 2 PlayStation 2 Slimline Fan Replacement: passo 6, immagine 2 di 2
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Fan Replacement: passo 7, immagine 1 di 2 PlayStation 2 Slimline Fan Replacement: passo 7, immagine 2 di 2
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Fan Replacement: passo 8, immagine 1 di 3 PlayStation 2 Slimline Fan Replacement: passo 8, immagine 2 di 3 PlayStation 2 Slimline Fan Replacement: passo 8, immagine 3 di 3
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
Conclusione
Altre 10 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 105
Tutti i Tempi: 8,335
