Introduzione
This guide will show you how to locate and replace the clock battery, sometimes known as a CMOS battery or motherboard battery, in the PlayStation 2 Slimline.
Disconnect all cables from the console and flip the unit over to reveal its base.
  • Disconnect all cables from the console and flip the unit over to reveal its base.
Aggiungi Commento
Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws. Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony. Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
  • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
Aggiungi Commento
Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver. Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver. Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
Aggiungi Commento
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit. Note: You may use your hands for additional force to separate the two pieces of the outer shell. Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
  • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Aggiungi Commento
Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
Aggiungi Commento
Lift the connector from the motherboard with a pair of tweezers using a firm, upward force. Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
Aggiungi Commento
Gently lift and remove the battery from its compartment using a spudger. Gently lift and remove the battery from its compartment using a spudger.
  • Gently lift and remove the battery from its compartment using a spudger.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Thomas Sullivan
Membro da: 23/10/2013
2.154 Reputazione
6 Guide realizzate
Ich wollte die Batterie wechseln, aber bei meiner PS2 Slim ist an der Stelle der Stecker des Laufwerkes fest? Und ich kann weit und breit keine Batterie entdecken. Weiß jemand warum das so ist? Gibt es verschiedene Revisionen, so dass die Batterie noch woanders sitzen könnte?
Lupo - Replica
This does not explain how to get the battery out of the black plastic, replace it, and put the wires back. That's the most important part!
Patrick Lewis - Replica
I believe that is because the clock battery is sold as a single unit. So there is no way to replace the actual battery inside.
Shahyah Darioosh -
Yeah, the battery’s a special-made CR2032 with two leads spot-welded onto the contact surfaces. You see it if you carefully remove the heat-shrink. Don’t EVER try to spot-weld or solder onto a lithium battery yourself. Just type “cr2032 cmos” or “cr2032 with leads” into your favorite parts store’s search bar. It should cost between three and ten us dollars. Keep the original, as you may need to salvage the original wired connector—these are made for a wide variety of (mostly-dell-laptop) applications, so the new battery will likely have a slightly different connector. If that’s the case, clip the original wires as near to where they connect to the battery as possible. Then, splice the original battery’s connector onto the new battery’s leads while maintaining polarity and remembering to insulate any bare wire that remains. Just tightly loop any excess wire after plugging the replacement in. Use a little strip of masking tape if you’re concerned about chassis pinching.
Allen Smith -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 183
Tutti i Tempi: 6,755
