Introduzione
If your headset had been working great but suddenly started producing static or distorted sounds, you may need to reset your headset. Follow these instructions:
Press and hold both the call control button and the listening volume/mute button for five seconds. When the talk indicator light blinks, release both buttons.
  • Press and hold both the call control button and the listening volume/mute button for five seconds.
  • When the talk indicator light blinks, release both buttons.
Aggiungi Commento
Press the call control button again.
  • Press the call control button again.
Aggiungi Commento
Unplug the base unit's power source for ten seconds. Plug the power source back in.
  • Unplug the base unit's power source for ten seconds.
  • Plug the power source back in.
Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Joe
Membro da: 12/04/2012
61 Reputazione
3 Guide realizzate
Cal Poly, Team 17-29, Amido Spring 2012 Membro di Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membri
7 Guide realizzate
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Replica
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Replica
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Replica
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 223
Tutti i Tempi: 14,070
