Salta al contenuto principale
Plantronics CS50 Headset Battery Replacement
Cosa ti serve
  1. Plantronics CS50 Headset Battery Replacement, Battery: passo 1, immagine 1 di 3 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, immagine 2 di 3 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Battery Replacement: passo 2, immagine 1 di 3 Plantronics CS50 Headset Battery Replacement: passo 2, immagine 2 di 3 Plantronics CS50 Headset Battery Replacement: passo 2, immagine 3 di 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
Conclusione
To reassemble your device, follow these instructions in reverse order
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-29, Amido Spring 2012 Membro di Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membri
7 Guide realizzate
Un commento
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 44
Tutti i Tempi: 7,362
