Introduzione
This guide will show how to replace the eyes and eye wire if either are damaged.
Parti
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side. Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Aggiungi Commento
Pull the grip away from the frame. Pull the grip away from the frame.
  • Pull the grip away from the frame.
Aggiungi Commento
Pull the grip through the opening. The grip is connected in the middle and is one piece.
  • Pull the grip through the opening.
  • The grip is connected in the middle and is one piece.
Aggiungi Commento
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline. It helps to rotate the collar to create room to pull out macroline. It helps to rotate the collar to create room to pull out macroline.
  • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
Aggiungi Commento
While pulling in the metal ring on the fitting, pull the macroline out. While pulling in the metal ring on the fitting, pull the macroline out. While pulling in the metal ring on the fitting, pull the macroline out.
  • While pulling in the metal ring on the fitting, pull the macroline out.
Aggiungi Commento
Use 1/8" allen wrench to remove screw behind regulator. Use 1/8" allen wrench to remove screw behind regulator. Use 1/8" allen wrench to remove screw behind regulator.
  • Use 1/8" allen wrench to remove screw behind regulator.
Aggiungi Commento
Use 1/8" allen wrench to loosen the screw inside the grip on the right side. The screw only needs to be turned a couple of times. Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
  • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
  • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
  • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Aggiungi Commento
Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires. Pull the wire through the opening. Pull the wire through the opening.
  • Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
  • Pull the wire through the opening.
Aggiungi Commento
Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.) Pull off eye covers. (Located on both sides of the paintball marker.) Pull off eye covers. (Located on both sides of the paintball marker.)
  • Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.)
  • Pull off eye covers. (Located on both sides of the paintball marker.)
Aggiungi Commento
Gently pull out the two eyes, one on each side of the paintball marker. The red wire leading to the eye on the right side of the paintball marker.  The black wire leads to the eye on the left side. The red wire leading to the eye on the right side of the paintball marker.  The black wire leads to the eye on the left side.
  • Gently pull out the two eyes, one on each side of the paintball marker.
    • The red wire leading to the eye on the right side of the paintball marker. The black wire leads to the eye on the left side.
Aggiungi Commento
Conclusione
To reassemble your device with a new eye wire, follow this guide in reverse.
Rett Triplett
Membro da: 18/10/2013
801 Reputazione
8 Guide realizzate
Clemson, Team 13-6, Benson Fall 2013 Membro di Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 712
