Salta al contenuto principale
Planet Eclipse Etha Trigger Replacement
Cosa ti serve
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: passo 1, immagine 1 di 2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: passo 1, immagine 2 di 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: passo 2, immagine 1 di 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: passo 3, immagine 1 di 2 Planet Eclipse Etha Trigger Replacement: passo 3, immagine 2 di 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: passo 4, immagine 1 di 1
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: passo 5, immagine 1 di 1
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: passo 6, immagine 1 di 2 Planet Eclipse Etha Trigger Replacement: passo 6, immagine 2 di 2
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
Conclusione
Evan Hench
Membro da: 10/19/14
211 Reputazione
1 Guida realizzata
Cal Poly, Team 10-42, Amido Fall 2014 Membro di Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 925
