Introduzione
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
Pry off the four white feet with the pointed end of the spudger
  • Pry off the four white feet with the pointed end of the spudger
Aggiungi Commento
Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Aggiungi Commento
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • The connectors on the panel are fragile and may break.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
  • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
  • The cables do not have a lot of slack in them. Be careful not to break the connectors.
  • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Aggiungi Commento
Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
Aggiungi Commento
Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
Aggiungi Commento
Separate the white suport bracket from the headphone/power electronics board.
  • Separate the white suport bracket from the headphone/power electronics board.
Aggiungi Commento
Conclusione
Graham Rolph
Membro da: 18/04/2013
1 Reputazione
2 Guide realizzate
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 912
