Introduzione
Follow the procedure outlined in this guide to remove and install the circuit board for the device's bottom buttons.
Pry off the four white feet with the pointed end of the spudger
  • Pry off the four white feet with the pointed end of the spudger
Aggiungi Commento
Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Aggiungi Commento
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • The connectors on the panel are fragile and may break.
Aggiungi Commento
Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
  • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
  • The cables do not have a lot of slack in them. Be careful not to break the connectors.
  • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Aggiungi Commento
Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
Aggiungi Commento
Pull the board out from the dock
  • Pull the board out from the dock
Aggiungi Commento
Conclusione
Greg Lane
Membro da: 16/04/2013
9 Reputazione
4 Guide realizzate
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
6 Guide realizzate
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 605
