Introduzione
Does your headlamp produce dim lighting despite a fresh set of batteries and a bulb? You may need to replace the lens piece - especially if the reflective mirror has become damaged or dull.
Strumenti
Nessun attrezzo richiesto.
Parti
Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
  • Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
Aggiungi Commento
Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
  • Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
Aggiungi Commento
Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
  • Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
Aggiungi Commento
Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
  • Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
Aggiungi Commento
Linea Traguardo
Mike
Membro da: 23/10/2014
314 Reputazione
3 Guide realizzate
Baylor, Team 8-10, Williams Fall 2014 Membro di Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 235
