Introduzione
This guide will teach you how to properly remove the cover of the camera.
Parti
Nessuna parte richiesta.
Remove the following screws: Two silver 3.15mm Phillips #00 screws on the right side of the camera
  • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
Aggiungi Commento
Remove the two indicated screws on the bottom of the camera:
  • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully pull the back of casing away from the front. Carefully pull the back of casing away from the front.
  • Carefully pull the back of casing away from the front.
Aggiungi Commento
After removing the back cover, several things must be removed. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  • After removing the back cover, several things must be removed.
  • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
Aggiungi Commento
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Aggiungi Commento
Conclusione
Nicole Wong
Membro da: 30/01/2011
329 Reputazione
3 Guide realizzate
Cal Poly, Team 4-29, Regan Winter 2011 Membro di Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,917
