Introduzione
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
Flip the quick release lever on the wheel. Flip the quick release lever on the wheel.
  • Flip the quick release lever on the wheel.
Aggiungi Commento
Squeeze the brake arms together and lift the brake cable from the caliper arms.
  • Squeeze the brake arms together and lift the brake cable from the caliper arms.
Aggiungi Commento
Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
Aggiungi Commento
Press the valve core while applying pressure to the tire to deflate the tire.
  • Press the valve core while applying pressure to the tire to deflate the tire.
Aggiungi Commento
Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel. Slide the lever around the circumference of the wheel to completely remove the tire.
  • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
  • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
Aggiungi Commento
Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
Aggiungi Commento
Aggiungi Commento
Aggiungi Commento
Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
Aggiungi Commento
Locate the leak by first over inflating the tire. Place the tire under water and look for bubbles to find the leak.
  • Locate the leak by first over inflating the tire.
  • Place the tire under water and look for bubbles to find the leak.
Aggiungi Commento
Mark the hole with a marker, and completely deflate the tire.
  • Mark the hole with a marker, and completely deflate the tire.
Aggiungi Commento
Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
Aggiungi Commento
Clean the area near the hole with soap and water, then dry it thoroughly.
  • Clean the area near the hole with soap and water, then dry it thoroughly.
  • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
Aggiungi Commento
Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
Aggiungi Commento
Apply the patch to the area.
  • Apply the patch to the area.
Aggiungi Commento
Apply pressure to the patch until the rubber cement is dry.
  • Apply pressure to the patch until the rubber cement is dry.
Aggiungi Commento
Conclusione
To reassemble your wheel, follow these instructions in reverse order starting at step three.
Altre 6 persone hanno completato questa guida.
Travis Tonder
Membro da: 05/10/2010
2.444 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,855
