Introduzione
Use this guide to diagnose and replace a faulty motor on your Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Panoramica Video
Remove the foam body. Remove the foam body.
  • Remove the foam body.
Aggiungi Commento
Disconnect the battery by pulling the two red wires apart. Remove the battery by releasing the battery retaining straps.
  • Disconnect the battery by pulling the two red wires apart.
  • Remove the battery by releasing the battery retaining straps.
how do i put the clips back in?
kuki vier - Replica
Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
David Hoyt -
Remove the small retaining clip using a plastic opening tool.
  • Remove the small retaining clip using a plastic opening tool.
  • Be careful as these clips can fly off and can be difficult to find.
Aggiungi Commento
The propeller, gear, and rod can be removed by simply lifting them off the motor. The propeller, gear, and rod can be removed by simply lifting them off the motor. The propeller, gear, and rod can be removed by simply lifting them off the motor.
  • The propeller, gear, and rod can be removed by simply lifting them off the motor.
Aggiungi Commento
Disconnect the connector at the bottom of the motor assembly. Disconnect the connector at the bottom of the motor assembly.
  • Disconnect the connector at the bottom of the motor assembly.
Aggiungi Commento
Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
Aggiungi Commento
Remove the three 5mm screws on the bottom again using a PH00 bit.
  • Remove the three 5mm screws on the bottom again using a PH00 bit.
  • The three screws from the top are different from the three screws on the bottom.
Aggiungi Commento
Carefully wiggle out the motor assembly out of the arm. Carefully wiggle out the motor assembly out of the arm.
  • Carefully wiggle out the motor assembly out of the arm.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
David Hoyt
Membro da: 09/04/2010
3.596 Reputazione
44 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
52 Guide realizzate
are the motors different on each side?
dbksoft - Replica
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 76
Tutti i Tempi: 3,414
