Introduzione
Use this guide to replace the foam hull of the Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Parti
Nessuna parte richiesta.
Panoramica Video
Peel off double sided tape and apply to one side of the broken hull. Peel off double sided tape and apply to one side of the broken hull.
  • Peel off double sided tape and apply to one side of the broken hull.
Aggiungi Commento
Cut the tape with scissors as close to the shape of the broken hull as possible. Cut the tape with scissors as close to the shape of the broken hull as possible.
  • Cut the tape with scissors as close to the shape of the broken hull as possible.
Aggiungi Commento
Peel off the other side of the tape and stick the two sides together. Peel off the other side of the tape and stick the two sides together.
  • Peel off the other side of the tape and stick the two sides together.
Aggiungi Commento
Conclusione
David Hoyt
Membro da: 09/04/2010
3.596 Reputazione
44 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
52 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,052
