Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock. Turn phone over so that the back side is facing up. Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
  • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
  • Turn phone over so that the back side is facing up.
  • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
  • Lift and remove the back cover from the phone.
Aggiungi Commento
Locate the battery:  It is a silver, rectangular object. Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
  • Locate the battery: It is a silver, rectangular object.
  • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
  • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
Aggiungi Commento
The slots for the Micro SD and SIM cards are directly above the battery tray. To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
  • The slots for the Micro SD and SIM cards are directly above the battery tray.
  • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
  • Micro SD Card Slot - On the Left
  • SIM Card Slot - On the Right
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Ryan Murphy
Membro da: 25/09/2014
850 Reputazione
14 Guide realizzate
USF Tampa, Team 5-5, Mcgee Fall 2014 Membro di USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,347
