Introduzione
This guide will show you how to remove the wireless card from a Panasonic Toughbook CF-29
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Aggiungi Commento
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Aggiungi Commento
Begin by turning the laptop upside down with the handle towards you.
  • Begin by turning the laptop upside down with the handle towards you.
  • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Aggiungi Commento
Remove the panel and set it aside.
  • Remove the panel and set it aside.
  • Use a Phillips size 0 screwdriver to remove these 8 small screws.
Aggiungi Commento
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Aggiungi Commento
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Aggiungi Commento
Be careful when lifting the cover as you may damage some connections.
  • Be careful when lifting the cover as you may damage some connections.
  • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Aggiungi Commento
Now the back cover should be off and you can access the inside of the casing.
  • Now the back cover should be off and you can access the inside of the casing.
Aggiungi Commento
Remove the black and white wires attached to the wireless card by simply pulling up.
  • Remove the black and white wires attached to the wireless card by simply pulling up.
Aggiungi Commento
Peel back the black cover to expose the clips holding in the wireless card.
  • Peel back the black cover to expose the clips holding in the wireless card.
Aggiungi Commento
Using a pair of plastic opening tools, push the two metal tabs away from the card.
  • Using a pair of plastic opening tools, push the two metal tabs away from the card.
Aggiungi Commento
The wireless card should now easily disengage from the motherboard. Pull the card horizontally away from you to remove it from its housing.
  • The wireless card should now easily disengage from the motherboard.
  • Pull the card horizontally away from you to remove it from its housing.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Devon Augustus
Membro da: 12/04/2010
97 Reputazione
2 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
12 Guide realizzate
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 13,274
