Introduzione
This guide will show you how to add or replace the RAM in your Toughbook CF-29.
Parti
Nessuna parte richiesta.
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Aggiungi Commento
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Aggiungi Commento
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Aggiungi Commento
Pull the clips aside to release and remove the RAM.
  • Pull the clips aside to release and remove the RAM.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Devon Augustus
Membro da: 12/04/2010
97 Reputazione
2 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
12 Guide realizzate
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 17,530
