Introduzione
This guide will show you how to remove the keyboard from the main unit.
Parti
Nessuna parte richiesta.
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Aggiungi Commento
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Aggiungi Commento
Remove the four screws above the keyboard using a Phillips #0 screwdriver.
  • Remove the four screws above the keyboard using a Phillips #0 screwdriver.
Aggiungi Commento
Pry up the black panel covering the top of the keyboard.
  • Pry up the black panel covering the top of the keyboard.
Aggiungi Commento
Remove the five silver screws shown.
  • Remove the five silver screws shown.
Aggiungi Commento
Pull up keyboard and place it face down on the trackpad
  • Pull up keyboard and place it face down on the trackpad
    • Be careful not to put tension in the ribbon cables attached to the underside of the keyboard
Aggiungi Commento
Remove screws shown from cover plate
  • Remove screws shown from cover plate
Aggiungi Commento
Pull cover plate out of place revealing the ribbon cable connections to the motherboard Pull cover plate out of place revealing the ribbon cable connections to the motherboard
  • Pull cover plate out of place revealing the ribbon cable connections to the motherboard
Aggiungi Commento
Remove the ribbon cable farthest from you. Push the white tab (as shown in the second photo) to release the ribbon cable.
  • Remove the ribbon cable farthest from you.
    • Push the white tab (as shown in the second photo) to release the ribbon cable.
Aggiungi Commento
Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
  • Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
Aggiungi Commento
Conclusione
Dylan Bloom
Membro da: 12/04/2010
262 Reputazione
4 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
12 Guide realizzate
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 45
Tutti i Tempi: 14,786
