Introduzione
Remove all necessary parts of the camcorder in order to gain access to remove and replace a bad logic board.
Cosa ti serve
Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
Remove the indicated 4.5mm screws from the LCD side of the camera.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
Remove the panel from the camcorder.
Using the spudger, remove the few remaining ribbon cables from the logic board.
To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board.
Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel.
Carefully lift the logic board away from the camcorder.
