Introduzione
A guide to removing the lens assembly on the camcorder.
Parti
Nessuna parte richiesta.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder. Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder. Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
  • Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Aggiungi Commento
Open the tape compartment. Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
  • Open the tape compartment.
  • Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
Aggiungi Commento
Use a plastic opening tool to remove the gray trim piece from top of the camcorder. Take care when removing the trim piece. The plastic parts are fragile and can break easily. Take care when removing the trim piece. The plastic parts are fragile and can break easily.
  • Use a plastic opening tool to remove the gray trim piece from top of the camcorder.
  • Take care when removing the trim piece. The plastic parts are fragile and can break easily.
Aggiungi Commento
Rotate the camcorder so that the eye piece is facing you, and remove the battery. Remove the four black 4.5mm screws, which sit behind the battery. Then, remove the 5th screw to the right of the battery dock.
  • Rotate the camcorder so that the eye piece is facing you, and remove the battery. Remove the four black 4.5mm screws, which sit behind the battery. Then, remove the 5th screw to the right of the battery dock.
  • Be careful not to lose any screws whilst trying to remove them.
Aggiungi Commento
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap. It may help you during this step to undo the strap on one end.
  • Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap.
  • It may help you during this step to undo the strap on one end.
  • Next, rotate the camcorder so that the lens is facing you. Remove the single 4.5mm black screw from the front panel.
Aggiungi Commento
Rotate the camcorder so that the bottom is facing towards you. Remove the single remaining 4.5mm black screw from the bottom. Next, while still having the bottom of the camcorder facing you, remove the four silver 4.5mm screws from the body.
  • Rotate the camcorder so that the bottom is facing towards you. Remove the single remaining 4.5mm black screw from the bottom.
  • Next, while still having the bottom of the camcorder facing you, remove the four silver 4.5mm screws from the body.
Aggiungi Commento
Open the LCD screen on the side of the camcorder.
  • Open the LCD screen on the side of the camcorder.
  • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
Aggiungi Commento
Very carefully remove the front cover from the main body of the camcorder. This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • Very carefully remove the front cover from the main body of the camcorder.
  • This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • There is a ribbon cable attached to the front panel and the camcorder body, so be careful not to pull that off when you remove this panel.
Aggiungi Commento
Using your fingers, carefully pull the ribbon cable away from the logic board. Using your fingers, carefully pull the ribbon cable away from the logic board.
  • Using your fingers, carefully pull the ribbon cable away from the logic board.
Aggiungi Commento
Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera. Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera.
  • Now, from where the front cover used to be, remove the two 4.5mm black screws from the LCD side of the camera.
Aggiungi Commento
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.  Using two tools may be useful, if difficult. Move the plastic opening tool up the side of the camcorder as shown, carefully separating the LCD panel from the rest of the camcorder. With the blue LCD panel free from the rest of the camcorder, remove the panel from the camcorder.
  • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder. Using two tools may be useful, if difficult.
  • Move the plastic opening tool up the side of the camcorder as shown, carefully separating the LCD panel from the rest of the camcorder.
  • With the blue LCD panel free from the rest of the camcorder, remove the panel from the camcorder.
Aggiungi Commento
Before you fully remove the LCD panel from the camcorder, be sure to remove the ribbon cables that connect the LCD panel to the logic board. There may be multiple ribbon cables attached to the same point on the logic board. There may be multiple ribbon cables attached to the same point on the logic board.
  • Before you fully remove the LCD panel from the camcorder, be sure to remove the ribbon cables that connect the LCD panel to the logic board.
  • There may be multiple ribbon cables attached to the same point on the logic board.
Aggiungi Commento
Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place. Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place.
  • Using #00 phillips screwdriver, remove two 4.5mm black screws holding lens in place.
Aggiungi Commento
Remove third 4.5mm lens mount screw near front of camera.
  • Remove third 4.5mm lens mount screw near front of camera.
Aggiungi Commento
Careful that both lens ribbon cables are removed from logic board, remove lens. Careful that both lens ribbon cables are removed from logic board, remove lens. Careful that both lens ribbon cables are removed from logic board, remove lens.
  • Careful that both lens ribbon cables are removed from logic board, remove lens.
Aggiungi Commento
Conclusione
Tommy
Membro da: 18/04/2010
97 Reputazione
2 Guide realizzate
Cal Poly, Team 7-9, Maness Spring 2010 Membro di Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,686
