Parti
Nessuna parte richiesta.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Aggiungi Commento
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Aggiungi Commento
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Aggiungi Commento
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Aggiungi Commento
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Aggiungi Commento
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Aggiungi Commento
Remove the back casing from the camera.
  • Remove the back casing from the camera.
Aggiungi Commento
Use a spudger to release the 3 clips between the LCD case and housing. Put the tip of the spudger in the gap between the clip and housing, then lift up gently to unclip.
  • Use a spudger to release the 3 clips between the LCD case and housing.
    • Put the tip of the spudger in the gap between the clip and housing, then lift up gently to unclip.
  • Gently lift the LCD from the case, making sure none of the 3 clips reattach.
Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
Ben Canfield
Membro da: 10/10/2010
391 Reputazione
3 Guide realizzate
Cal Poly, Team 9-21, Regan Fall 2010 Membro di Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Membri
7 Guide realizzate
If you want to go the easy route as shown above, then buy the LCD/backlight kit from Panasonic. Otherwise, if you buy the bare LCD (99% of online retails sell the bare LCD, no kit) then you have a 30 minute install on your hands. The bare LCD is nested within a metal/plastic frame which is nested in the backlight frame which is where the above tutorial ends. You'll need dextrous fingers to get the frames off of each other or else you risk bending the frame. Btw, DO NOT remove any tape. Removal of tape is not necessary and may cause visual or circuitry problems.
tonnage - Replica
This guide also works for the TZ7, slightly different screw arrangement but otherwise the process is identical.
I had a bare LCD kit so the last step was trickier than the guide shows, the note above is accurate, the extra frames are quite flimsy so care is required. But I am no watchmaker and I managed it ok; it is just a bit slower than the guide shows.
cotsweb - Replica
Totally agree with the above notes, however the circuit tapes on mine were under the adhesive tape on the backlight, meaning this had to be lifted in the one area to release the circuit tape off the LCD glass. Make a good note of the orientation of the LCD / Backlight glass parts in the frame as there is a metal frame, plastic surround, gasket and the two glass parts all to get back together the right way up and round. Lay it out and make a note if needed as you take it apart and it should work ok - I did find pushing the 2 conductor parts back into the circuit board quite tricky.
Jon Worsfold -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 134
Tutti i Tempi: 30,849
