Introduzione
Fixing the lens apparatus on your camera.
Parti
Nessuna parte richiesta.
Slide the lock into the unlock position.In this case you would need to slide the lock to the right.
  • Slide the lock into the unlock position.In this case you would need to slide the lock to the right.
  • Use your finger to slide battery hatch towards the arrow sign.
  • Both battery and memory card should now be visible.
Aggiungi Commento
Open battery hatch and the black cover to expose the battery compartment.
  • Open battery hatch and the black cover to expose the battery compartment.
  • The camera used to create these repair guides did not have a battery and memory card.
  • Pull the battery out and replace with a new one.
  • When putting the battery back in, make sure it is in the same orientation as before.
  • Close the battery compartment and make sure the lock is in the locked position.
Aggiungi Commento
Remove the two 2.8 mm Phillips screws as shown in picture.
  • Remove the two 2.8 mm Phillips screws as shown in picture.
Aggiungi Commento
Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
  • Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
Aggiungi Commento
Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture. /state that a screwdriver is needed in the  step.
  • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture. /state that a screwdriver is needed in the step.
Aggiungi Commento
Use a Spudger tool to pry open case from all sides./No edits necessary Use a Spudger tool to pry open case from all sides./No edits necessary
  • Use a Spudger tool to pry open case from all sides./No edits necessary
Aggiungi Commento
Beware of yellow film strip when opening./Caution: Beware of the yellow film strip when opening  the casing of the camera, make this caution notice a different color. Use your fingers to carefully pry off the back casing from the camera assembly/. No edits necessary.
  • Beware of yellow film strip when opening./Caution: Beware of the yellow film strip when opening the casing of the camera, make this caution notice a different color.
  • Use your fingers to carefully pry off the back casing from the camera assembly/. No edits necessary.
Aggiungi Commento
Lay the camera on its front side./combine this sentence to the step below.
  • Lay the camera on its front side./combine this sentence to the step below.
  • Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
  • Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
Aggiungi Commento
Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
  • Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
  • The other three screws shown in picture were removed to take off the back case.
Aggiungi Commento
Using Spudger tool, pry the front case from the camera's components. Use your fingers to carefully pull the back case from the front case. Cut the black and red wires connecting front case to the body of the camera.
  • Using Spudger tool, pry the front case from the camera's components.
  • Use your fingers to carefully pull the back case from the front case.
  • Cut the black and red wires connecting front case to the body of the camera.
  • Being careful nothing get's caught, separate the front case from the camera.
  • To put the new front case back on, solder the wires of the new front case to the components of the camera.
Aggiungi Commento
Check the "V" shaped spring to see if it is connected at shown location.
  • Check the "V" shaped spring to see if it is connected at shown location.
Aggiungi Commento
Manually move the Lens Apparatus from the inside to shown position.
  • Manually move the Lens Apparatus from the inside to shown position.
  • Check to see if the spring is aligned correctly and lens opens.
  • If not, you will need to take out the spring and place it into the proper position, or get a new spring all together.
  • To reassemble your device, follow these instructions in reverse order.
Aggiungi Commento
Conclusione
Alex Penman
Membro da: 28/01/2011
463 Reputazione
4 Guide realizzate
Cal Poly, Team 7-35, Regan Winter 2011 Membro di Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,164
