Introduzione
Use this guide to remove the right function board from the front panel of the DVD player.
Parti
Nessuna parte richiesta.
Eject the disk tray from the DVD player before removing power supply.
  • Eject the disk tray from the DVD player before removing power supply.
Aggiungi Commento
Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
  • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
Aggiungi Commento
Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
  • Remove 3 screws running along back edge of case cover.
  • Remove 2 screws from each side of case cover.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Grab edges of cover, pull outward slightly, and pull straight up.
  • Grab edges of cover, pull outward slightly, and pull straight up.
Aggiungi Commento
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Aggiungi Commento
Remove 4 screws as shown.
  • Remove 4 screws as shown.
Aggiungi Commento
Push in plastic retainer tab on board. Grasp edges of board and pull out. Grasp edges of board and pull out.
  • Push in plastic retainer tab on board.
  • Grasp edges of board and pull out.
Aggiungi Commento
Conclusione
Kevin
Membro da: 26/04/2011
351 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,873
