Parti
Nessuna parte richiesta.
Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
  • Remove 3 screws running along back edge of case cover.
  • Remove 2 screws from each side of case cover.
Aggiungi Commento
Grab edges of cover, pull outward slightly, and pull straight up.
  • Grab edges of cover, pull outward slightly, and pull straight up.
Aggiungi Commento
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Aggiungi Commento
Grip jogger dial and lift up. It should come off easily. Grip jogger dial and lift up. It should come off easily.
  • Grip jogger dial and lift up. It should come off easily.
Aggiungi Commento
Remove 4 mounting screws as shown. Unscrew and save brass tab. Push in 2 plastic retainers and lift out.
  • Remove 4 mounting screws as shown.
  • Unscrew and save brass tab.
  • Push in 2 plastic retainers and lift out.
Aggiungi Commento
Conclusione
Kevin
Membro da: 26/04/2011
351 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,027
