Salta al contenuto principale
Panasonic DVD-RV31 Player Front Panel Replacement
Cosa ti serve
  1. Panasonic DVD-RV31 Player Front Panel Replacement, Disk Tray Cover: passo 1, immagine 1 di 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Front Panel Replacement: passo 2, immagine 1 di 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: passo 3, immagine 1 di 2 Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: passo 3, immagine 2 di 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic DVD-RV31 Player Front Panel Replacement: passo 4, immagine 1 di 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: passo 5, immagine 1 di 2 Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: passo 5, immagine 2 di 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Conclusione
Kevin
Membro da: 04/26/11
375 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,513
