Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device. Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
Aggiungi Commento
Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
  • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire label off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
Aggiungi Commento
Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
Aggiungi Commento
Use either side of the spudger to carefully pry off the camera lens mesh cover.
  • Use either side of the spudger to carefully pry off the camera lens mesh cover.
Aggiungi Commento
Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
Aggiungi Commento
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off. Gently remove the case to avoid damaging it. Do not try to force the case open.
  • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
Aggiungi Commento
Remove the cover by lifting it from right to left. This should be similar to the action of the opening of a book.
  • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done correctly.
Aggiungi Commento
Lift the control buttons off of the motherboard.
  • Lift the control buttons off of the motherboard.
Aggiungi Commento
Wedge the flat end of the spudger underneath the battery and gently pry it out.
  • Wedge the flat end of the spudger underneath the battery and gently pry it out.
    • Be cautious of the red and black wires on the battery, which may rip easily.
    • The battery may have adhesive holding it to the device.
    • The battery connector may rip if the battery is not removed carefully.
Aggiungi Commento
Gently disconnect the white component connecting the battery to the motherboard.
  • Gently disconnect the white component connecting the battery to the motherboard.
    • The connector should be pulled upward.
Aggiungi Commento
Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
  • Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
Aggiungi Commento
Disconnect the orange video connector leading from the lower case to the upper case with the pointed end of the spudger. The orange video connector is the cable that connects the motherboard to the screen.
  • Disconnect the orange video connector leading from the lower case to the upper case with the pointed end of the spudger.
    • The orange video connector is the cable that connects the motherboard to the screen.
Aggiungi Commento
Use the spudger to unclip the screen in the lower left corner and gently pry it from its clips.
  • Use the spudger to unclip the screen in the lower left corner and gently pry it from its clips.
Aggiungi Commento
Grabbing the left and right edges of the front panel, flex the front panel outward until the screen pops out.
  • Grabbing the left and right edges of the front panel, flex the front panel outward until the screen pops out.
    • The panel should only be flexed to the point that the screen can come out. Flexing it more will most likely break it.
Aggiungi Commento
Lift screen from panel. Lift screen from panel.
  • Lift screen from panel.
Aggiungi Commento
Conclusione
Michelle Medina
Membro da: 10/04/2012
63 Reputazione
10 Guide realizzate
Cal Poly, Team 6-49, Amido Spring 2012 Membro di Cal Poly, Team 6-49, Amido Spring 2012
CPSU-AMIDO-S12S6G49
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 567
