Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device. Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
Aggiungi Commento
Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
  • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire label off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
Aggiungi Commento
Use a #00 Phillips screwdriver to remove the 2.5 mm hidden screw.
  • Use a #00 Phillips screwdriver to remove the 2.5 mm hidden screw.
Aggiungi Commento
Use either end of the spudger to carefully pry off the camera lens mesh cover.
  • Use either end of the spudger to carefully pry off the camera lens mesh cover.
Aggiungi Commento
Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
Aggiungi Commento
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off. Gently remove the case to avoid damaging it.
  • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
Aggiungi Commento
Remove the cover by lifting it from right to left. This should be similar to the action of the opening of a book.
  • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
Aggiungi Commento
Remove the control pad buttons from the device and set aside.
  • Remove the control pad buttons from the device and set aside.
Aggiungi Commento
Wedge the flat end of the spudger underneath the battery and gently pry it out.
  • Wedge the flat end of the spudger underneath the battery and gently pry it out.
    • Be cautious of the red and black wires on the battery, which may rip easily.
    • The battery may have adhesive holding it to the device.
    • Be careful with the battery connector, which may rip.
Aggiungi Commento
Gently disconnect the white component connecting the battery to the motherboard.
  • Gently disconnect the white component connecting the battery to the motherboard.
    • The connector should be pulled upward.
Aggiungi Commento
Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
  • Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
Aggiungi Commento
Unplug the orange video connector leading from the lower case to the upper case. The orange video connector is the cable that connects the motherboard to the screen.
  • Unplug the orange video connector leading from the lower case to the upper case.
    • The orange video connector is the cable that connects the motherboard to the screen.
Aggiungi Commento
Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
  • Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side.
    • If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
Aggiungi Commento
Using the spudger, pry the motherboard off of the device.
  • Using the spudger, pry the motherboard off of the device.
  • We recommend removing the motherboard off of the device from left to right.
Aggiungi Commento
Feed the video connector from the camera through the square hole in the motherboard. After doing so, you may carefully lift the motherboard out of the back case.
  • Feed the video connector from the camera through the square hole in the motherboard.
  • After doing so, you may carefully lift the motherboard out of the back case.
Aggiungi Commento
Using tweezers, pry one side of the clip off.
  • Using tweezers, pry one side of the clip off.
Aggiungi Commento
Now that the camera is loose, you may pick it up and remove it from the case.
  • Now that the camera is loose, you may pick it up and remove it from the case.
Aggiungi Commento
Conclusione
Michelle Medina
Membro da: 10/04/2012
63 Reputazione
10 Guide realizzate
Cal Poly, Team 6-49, Amido Spring 2012 Membro di Cal Poly, Team 6-49, Amido Spring 2012
CPSU-AMIDO-S12S6G49
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 254
