Introduzione
How remove the outer casing
Lay device face down on surface.
  • Lay device face down on surface.
Aggiungi Commento
Heat the left and top edges with hairdryer for one minute. Move hairdryer back and forth to evenly heat up surface.
  • Heat the left and top edges with hairdryer for one minute.
  • Move hairdryer back and forth to evenly heat up surface.
  • Caution: directly heating the screen can melt or distort the screen.
Aggiungi Commento
Spedizione gratuita su tutti gli ordini da 79,00 US$ in su.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Use tweezers to hold Palm right side down on it's side.
  • Use tweezers to hold Palm right side down on it's side.
  • Use a plastic opening tool to pry open front and back casing.
  • If you are unable to open you may need to heat with hairdryer for longer.
  • Be sure not to touch case directly with fingers, it will be hot!
Aggiungi Commento
Leave plastic opening tools in between front and back casing.
  • Leave plastic opening tools in between front and back casing.
  • Rotate Palm and repeat steps 2 and 3 for right and back edges.
Aggiungi Commento
Now pry open front and back casing with plastic opening tools. Separate front and back casing completely. Power button will fall off once front and back casing have been removed. Be sure not to lose it.
  • Now pry open front and back casing with plastic opening tools.
  • Separate front and back casing completely.
  • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Aggiungi Commento
Linea Traguardo
Anthony Platt
Membro da: 09/02/2010
24 Reputazione
3 Guide realizzate
Cal Poly, Team 13-25, Maness Winter 2010 Membro di Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Membri
4 Guide realizzate
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,318
