Salta al contenuto principale
Palm m500 Battery Replacement
Cosa ti serve
  1. Palm m500 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 Battery Replacement: passo 2, immagine 1 di 2 Palm m500 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 Battery Replacement: passo 3, immagine 1 di 3 Palm m500 Battery Replacement: passo 3, immagine 2 di 3 Palm m500 Battery Replacement: passo 3, immagine 3 di 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 Battery Replacement, Battery: passo 4, immagine 1 di 3 Palm m500 Battery Replacement, Battery: passo 4, immagine 2 di 3 Palm m500 Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 14-9, Forte Winter 2011 Membro di Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 45
Tutti i Tempi: 4,995
