Introduzione
Before you begin disassembly, be sure to have the necessary tool. You will need a Torx size T6 screwdriver. You will be removing the stylus in order to take off the back panel.
Parti
Nessuna parte richiesta.
Remove the stylus from the side of the PDA by sliding it upwards.
  • Remove the stylus from the side of the PDA by sliding it upwards.
Aggiungi Commento
Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver. Place screws in a plastic bag or another safe place.
  • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
  • Place screws in a plastic bag or another safe place.
Aggiungi Commento
Insert the edge of the plastic opening tool between the back panel and the black stylus holder. Carefully and forcefully pry the panels apart. Carefully and forcefully pry the panels apart.
  • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
  • Carefully and forcefully pry the panels apart.
Aggiungi Commento
Conclusione
Alex Haggblade
Membro da: 12/01/2011
104 Reputazione
1 Guida realizzata
Cal Poly, Team 14-9, Forte Winter 2011 Membro di Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 960
