Salta al contenuto principale
Palm m105 Motherboard Replacement
Cosa ti serve
  1. Palm m105 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Start with your intact Palm m105.
  2. Palm m105 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  3. Palm m105 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off
  4. Palm m105 Motherboard Replacement: passo 4, immagine 1 di 2 Palm m105 Motherboard Replacement: passo 4, immagine 2 di 2
    • Using a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  5. Palm m105 Motherboard Replacement: passo 5, immagine 1 di 1
    • This is what the device looks like once you have taken the screws out and opened the device.
  6. Palm m105 Motherboard Replacement: passo 6, immagine 1 di 1
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  7. Palm m105 Motherboard Replacement: passo 7, immagine 1 di 1
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  8. Palm m105 Motherboard Replacement: passo 8, immagine 1 di 1
Conclusione
Aaron
Membro da: 10/04/11
7 Reputazione
1 Guida realizzata
UW Stout, Team 1-3, Zhou Fall 2011 Membro di UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,059
