Introduzione
If the front and/or rear cover is cracked, this guide will teach the user to remove the damaged cover and replace with a new one.
Parti
Nessuna parte richiesta.
Remove the batteries.
  • Remove the batteries.
Aggiungi Commento
Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
Aggiungi Commento
Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover. Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
Aggiungi Commento
Set aside broken cover, and replace with a new cover.
  • Set aside broken cover, and replace with a new cover.
Aggiungi Commento
Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
Aggiungi Commento
Put the back cover on the device and screw the four screws, screwing in a clockwise direction.  Take caution not to over-tighten the screws.
  • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Aggiungi Commento
Conclusione
Anne Carey
Membro da: 25/10/2011
1 Reputazione
3 Guide realizzate
James Madison, Team 1-3, Allen Fall 2011 Membro di James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 457
