Introduzione
This guide is to show you how to replace the battery on Palm Zire 71.
Flip the phone over
  • Flip the phone over
  • Slide the back cover upward to open
Aggiungi Commento
Use Torx T5 screwdriver to remove the top screws
  • Use Torx T5 screwdriver to remove the top screws
Aggiungi Commento
Remove the back sticker
  • Remove the back sticker
  • Remove the bottom Philips #00 screws
Aggiungi Commento
Turn to the frontside Slide the screen upward a little higher WITHOUT detaching the screen
  • Turn to the frontside
  • Slide the screen upward a little higher WITHOUT detaching the screen
  • Use the plastic opening tool to pry off the front panel
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the bottom Philips #00 screws Remove the bracket
  • Remove the bracket
  • Use the plastic opening tool to pry off the speaker
Aggiungi Commento
Slide the back cover off Slide the back cover off
  • Slide the back cover off
Aggiungi Commento
Remove the Philips #00 screw
  • Remove the Philips #00 screw
  • Remove the sliver metal piece
Aggiungi Commento
Remove the Philips screws #00 Remove the rear blue panel by prying both sides using the plastic opening tool
  • Remove the Philips screws #00
  • Remove the rear blue panel by prying both sides using the plastic opening tool
Aggiungi Commento
Remove the black plastic sticker Pull the tap up to remove the metal cap Pull the tap up to remove the metal cap
  • Remove the black plastic sticker
  • Pull the tap up to remove the metal cap
Aggiungi Commento
Remove the cable by pinching the sides and pulling Pry off the battery with the plastic opening tool Insert the new battery
  • Remove the cable by pinching the sides and pulling
  • Pry off the battery with the plastic opening tool
  • Insert the new battery
Aggiungi Commento
Conclusione
Jinxian Jiang
Membro da: 28/04/2011
11 Reputazione
6 Guide realizzate
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 6,651
