Salta al contenuto principale
Palm Zire 71 Back Cover Replacement
Cosa ti serve
  1. Palm Zire 71 Back Cover Replacement, Preparation: passo 1, immagine 1 di 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: passo 2, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: passo 3, immagine 1 di 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: passo 4, immagine 1 di 2 Palm Zire 71 Back Cover Replacement, Front Panel Removal: passo 4, immagine 2 di 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: passo 5, immagine 1 di 2 Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: passo 5, immagine 2 di 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Back Cover Replacement, Back Cover: passo 6, immagine 1 di 2 Palm Zire 71 Back Cover Replacement, Back Cover: passo 6, immagine 2 di 2
    • Slide the back cover off.
Conclusione
Jinxian Jiang
Membro da: 04/28/11
245 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,461
