Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Aggiungi Commento
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Aggiungi Commento
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Aggiungi Commento
The soldering iron heats up leads, wires, and everything else it touches that is metal.  Leaving it on too long may damage the board or burn you.
  • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
  • Desolder the speaker wires and solder the new speaker in its place.
  • The black and red wires are connected to the two solder bulbs in the yellow box.
Aggiungi Commento
Conclusione
Gabe
Membro da: 23/01/2011
501 Reputazione
5 Guide realizzate
Cal Poly, Team 5-21, Amido Winter 2011 Membro di Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 489
