Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Aggiungi Commento
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Aggiungi Commento
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Aggiungi Commento
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Aggiungi Commento
The blue keys will either come off with the blue front case, or stay on the motherboard.
  • The blue keys will either come off with the blue front case, or stay on the motherboard.
Aggiungi Commento
Conclusione
Gabe
Membro da: 23/01/2011
501 Reputazione
5 Guide realizzate
Cal Poly, Team 5-21, Amido Winter 2011 Membro di Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 474
