Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Aggiungi Commento
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Aggiungi Commento
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Aggiungi Commento
Using the spudger, pry the battery from where it is glued from the motherboard and observe that the leads are soldered on.
  • Using the spudger, pry the battery from where it is glued from the motherboard and observe that the leads are soldered on.
Aggiungi Commento
Heating up the soldering iron properly, place the wick against the solder bulbs and heat the solder until the solder wick sucks up the solder.
  • Heating up the soldering iron properly, place the wick against the solder bulbs and heat the solder until the solder wick sucks up the solder.
  • Be careful to not leave the soldering iron on the board too long as you may remove the copper leads or damage the motherboard.
  • Solder the new battery's leads to the motherboard by taking the heated iron and heating the exposed wires of the leads and placing the solder in contact with the leads so the solder heats up and flows onto the leads.
  • Pull away the heat immediately once the solder has flowed and let the board cool to avoid damage to the board (or burns on your hand).
Aggiungi Commento
Place the battery back on the board gently.
  • Place the battery back on the board gently.
  • The glue on the board should still stick, and you will want to be sure its exactly where it was or else the device will not reassemble properly.
Aggiungi Commento
Conclusione
Gabe
Membro da: 23/01/2011
501 Reputazione
5 Guide realizzate
Cal Poly, Team 5-21, Amido Winter 2011 Membro di Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,479
