Salta al contenuto principale
Palm Treo 680 screen replacement
Cosa ti serve
  1. Palm Treo 680 screen replacement, Battery: passo 1, immagine 1 di 2 Palm Treo 680 screen replacement, Battery: passo 1, immagine 2 di 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 screen replacement: passo 2, immagine 1 di 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 screen replacement, Back Panel: passo 3, immagine 1 di 2 Palm Treo 680 screen replacement, Back Panel: passo 3, immagine 2 di 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 screen replacement: passo 4, immagine 1 di 2 Palm Treo 680 screen replacement: passo 4, immagine 2 di 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 screen replacement: passo 5, immagine 1 di 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 screen replacement: passo 6, immagine 1 di 3 Palm Treo 680 screen replacement: passo 6, immagine 2 di 3 Palm Treo 680 screen replacement: passo 6, immagine 3 di 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, immagine 1 di 3 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, immagine 2 di 3 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, immagine 3 di 3
    • Take the front of the pannel and take notice that the screen is attached by a piece of silver tape.
    • Using a pair of tweezers, carefully peel off this piece of silver tape.
    • Remove the screen from the front pannel by pushing it out.
  8. Palm Treo 680 screen replacement: passo 8, immagine 1 di 2 Palm Treo 680 screen replacement: passo 8, immagine 2 di 2
    • Locate the 2 small plastic flaps that hold the small orange ribbons in place on both sides. Using a small metal spudger, flip up both of the flaps.
    • Do the same thing for one flap that you do for the other.
  9. Palm Treo 680 screen replacement: passo 9, immagine 1 di 3 Palm Treo 680 screen replacement: passo 9, immagine 2 di 3 Palm Treo 680 screen replacement: passo 9, immagine 3 di 3
    • Flip the screen over 180 degrees and take off the metal piece that cushions the screen.
    • Flip the screen over another another 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
    • Do not pull the two screens completely apart yet.
    • Slightly start to pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are.
    • This part is tricky and might take some maneuvering and a little bit of force, but it is possible!
  10. Palm Treo 680 screen replacement: passo 10, immagine 1 di 3 Palm Treo 680 screen replacement: passo 10, immagine 2 di 3 Palm Treo 680 screen replacement: passo 10, immagine 3 di 3
    • Move your thumbs to the other corner of the screen and slightly start to pull apart the touch screen from the LCD screen.
    • Carefully peel the touch screen away from the LCD screen.
    • Now you should have both the touch screen and LCD screen detached from one another.
Conclusione
Altre 2 persone hanno completato questa guida.
Maiya123
Membro da: 10/22/09
51 Reputazione
6 Guide realizzate
Cal Poly, Team 6-4, Maness Fall 2009 Membro di Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Membri
12 Guide realizzate
2 Commenti
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
chinthalaprasad - Replica
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,427
