Salta al contenuto principale
Palm Treo 680 Keyboard Replacement
Cosa ti serve
  1. Palm Treo 680 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Palm Treo 680 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Keyboard Replacement, Back Panel: passo 3, immagine 1 di 2 Palm Treo 680 Keyboard Replacement, Back Panel: passo 3, immagine 2 di 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Keyboard Replacement: passo 4, immagine 1 di 2 Palm Treo 680 Keyboard Replacement: passo 4, immagine 2 di 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Keyboard Replacement: passo 6, immagine 1 di 3 Palm Treo 680 Keyboard Replacement: passo 6, immagine 2 di 3 Palm Treo 680 Keyboard Replacement: passo 6, immagine 3 di 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Keyboard Replacement, Motherboard: passo 7, immagine 1 di 2 Palm Treo 680 Keyboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Slide the slim metal plate upwards until it disconnects from the motherboard.
    • DO NOT bend or crinkle this metal plate. It will be VERY DIFFICULT, IF NOT IMPOSSIBLE, to slide it back into place when you are re-assembling if you bend or crinkle this metal plate.
  8. Palm Treo 680 Keyboard Replacement: passo 8, immagine 1 di 2 Palm Treo 680 Keyboard Replacement: passo 8, immagine 2 di 2
    • Locate the orange ribbon that connects the screen to the motherboard.
    • Use tweezers to peel off the small piece of tape over the orange ribbon connector.
  9. Palm Treo 680 Keyboard Replacement: passo 9, immagine 1 di 2 Palm Treo 680 Keyboard Replacement: passo 9, immagine 2 di 2
    • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
    • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  10. Palm Treo 680 Keyboard Replacement: passo 10, immagine 1 di 3 Palm Treo 680 Keyboard Replacement: passo 10, immagine 2 di 3 Palm Treo 680 Keyboard Replacement: passo 10, immagine 3 di 3
    • Carefully turn the phone over so the screen is face up.
    • Locate the other orange ribbon that connects the motherboard to the faceplate.
    • Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
    • Separate the motherboard and faceplate of the Palm Treo.
  11. Palm Treo 680 Keyboard Replacement, Keyboard: passo 11, immagine 1 di 2 Palm Treo 680 Keyboard Replacement, Keyboard: passo 11, immagine 2 di 2
    • Locate the backside of the Treo's faceplate.
    • Remove the two screws using the T6 Torx screwdriver.
  12. Palm Treo 680 Keyboard Replacement: passo 12, immagine 1 di 2 Palm Treo 680 Keyboard Replacement: passo 12, immagine 2 di 2
    • Take off the plastic back panel, to gain access to the rubber keys of the keyboard.
    • Push on the keys and function bar from the front of the Treo. They should all pop right out.
Conclusione
Maiya123
Membro da: 10/22/09
51 Reputazione
6 Guide realizzate
Cal Poly, Team 6-4, Maness Fall 2009 Membro di Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,815
