Introduzione
This guide shows you how to take off the back panel to the Palm Treo 680 in order to reach the other components within side the phone.
Remove the battery cover by pressing on the small rectangular button location the back of the phone. Remove the battery cover by pressing on the small rectangular button location the back of the phone.
  • Remove the battery cover by pressing on the small rectangular button location the back of the phone.
Aggiungi Commento
Remove the battery by pulling it out toward you.
  • Remove the battery by pulling it out toward you.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Unscrew the 0.266 inch top-left screw with a T6 Torx Screwdriver. Be sure to remove the stylus in order to access the screw.
  • Unscrew the 0.266 inch top-left screw with a T6 Torx Screwdriver.
  • Be sure to remove the stylus in order to access the screw.
Use a T5 Torx screwdriver instead of a T6. T6 is too big.
Rhebakah Thomas - Replica
I found T5 too large as well. T4 seeems to work
Absent Minded Professor - Replica
Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device. Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
  • Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device.
  • Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
    • If there is a red Palm sticker covering the screw, just puncture it to access the screw.
Aggiungi Commento
Remove the remaining two 0.266 inch screws at the bottom of the device.
  • Remove the remaining two 0.266 inch screws at the bottom of the device.
Aggiungi Commento
Turn the phone 90 degrees to the right, so the screen is facing the right side. Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone. Separate the covers from the left side of the device as indicated in the picture. The right side contains orange ribbons that are easily damaged.
  • Turn the phone 90 degrees to the right, so the screen is facing the right side.
  • Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone.
  • Separate the covers from the left side of the device as indicated in the picture. The right side contains orange ribbons that are easily damaged.
Aggiungi Commento
Conclusione
Maiya123
Membro da: 22/10/2009
36 Reputazione
12 Guide realizzate
Cal Poly, Team 6-4, Maness Fall 2009 Membro di Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,661
