Introduzione
A guide for removing and replacing the phone's microphone.
Position the phone so the screen faces down.
  • Position the phone so the screen faces down.
  • Remove the stylus found on the back of the phone.
Aggiungi Commento
To remove the battery cover, hold down the button in the middle of the phone's back.
  • To remove the battery cover, hold down the button in the middle of the phone's back.
  • Slide the cover down to remove. Set the cover aside.
Aggiungi Commento
Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
  • Lift the edge of the battery, separating contact points, and pull out as pictured.
Aggiungi Commento
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • This will uncover a screw that will be removed in the next step.
Aggiungi Commento
Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver. Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver. Pull out antenna.
  • Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
  • Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
  • Pull out antenna.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
  • Pry the back cover off using a spudger or similar tool.
  • The back cover is attached by several small clips on the inside.
Aggiungi Commento
Unclip the gray tab. Pull out the orange ribbon cable. Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
  • Unclip the gray tab.
  • Pull out the orange ribbon cable.
  • Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
Aggiungi Commento
Pull off the mother board. Install replacement or repaired motherboard, reversing steps above.
  • Pull off the mother board.
  • Install replacement or repaired motherboard, reversing steps above.
Aggiungi Commento
Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
Aggiungi Commento
Pull off the circuit board.
  • Pull off the circuit board.
Aggiungi Commento
Remove the keypad for cleaning or replacing.
  • Remove the keypad for cleaning or replacing.
Aggiungi Commento
Place the circuit board with the microphone facing up.
  • Place the circuit board with the microphone facing up.
Aggiungi Commento
The microphone should be able to pop off easily using your finger. The microphone should be able to pop off easily using your finger.
  • The microphone should be able to pop off easily using your finger.
Aggiungi Commento
Conclusione
cgood
Membro da: 28/10/2009
116 Reputazione
14 Guide realizzate
Cal Poly, Team 19-3, Maness Fall 2009 Membro di Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,365
