Introduzione
This is a repair guide to access and replace the LCD screen.
Position the phone so the screen faces down.
  • Position the phone so the screen faces down.
  • Remove the stylus found on the back of the phone.
Aggiungi Commento
To remove the battery cover, hold down the button in the middle of the phone's back.
  • To remove the battery cover, hold down the button in the middle of the phone's back.
  • Slide the cover down to remove. Set the cover aside.
Aggiungi Commento
Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
  • Lift the edge of the battery, separating contact points, and pull out as pictured.
Aggiungi Commento
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
  • This will uncover a screw that will be removed in the next step.
Aggiungi Commento
Spedizione gratuita su tutti gli ordini da 79,00 US$ in su.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver. Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver. Pull out antenna.
  • Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
  • Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
  • Pull out antenna.
Aggiungi Commento
Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
  • Pry the back cover off using a spudger or similar tool.
  • The back cover is attached by several small clips on the inside.
Aggiungi Commento
Unclip the gray tab. Pull out the orange ribbon cable. Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
  • Unclip the gray tab.
  • Pull out the orange ribbon cable.
  • Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
Aggiungi Commento
Pull off the mother board. Install replacement or repaired motherboard, reversing steps above.
  • Pull off the mother board.
  • Install replacement or repaired motherboard, reversing steps above.
Aggiungi Commento
Lift up the LCD screen so that the ribbon strip connecting it to the motherboard can be accessed. Be careful not to pull off LCD screen yet. Be careful not to pull off LCD screen yet.
  • Lift up the LCD screen so that the ribbon strip connecting it to the motherboard can be accessed.
  • Be careful not to pull off LCD screen yet.
Aggiungi Commento
Unclip the gray tab. Pull out the orange ribbon strip.
  • Pull out the orange ribbon strip.
  • Remove the LCD screen.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
cgood
Membro da: 28/10/2009
116 Reputazione
14 Guide realizzate
Cal Poly, Team 19-3, Maness Fall 2009 Membro di Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 4,793
