Introduzione
Steps to follow if you want to replace the logic board. Also needed if you want to access the camera.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Aggiungi Commento
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Aggiungi Commento
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Aggiungi Commento
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Aggiungi Commento
Lift up the silver casing.
  • Lift up the silver casing.
  • Careful! The casing is connected to the body. Pull the casing up.
Aggiungi Commento
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Aggiungi Commento
Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone.
  • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Aggiungi Commento
Conclusione
Clement Poisson
Membro da: 26/01/2010
24 Reputazione
14 Guide realizzate
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,403
