Introduzione
Follow this guide if the battery is dysfunctional and you want to replace it.
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Aggiungi Commento
Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
  • Use the T6 Torx Screwdriver to remove all 4 screws.
  • You have to first remove the Stylus to access the 4th screw.
Aggiungi Commento
Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
  • Using a plastic opening tool, carefully separate the front and back cases.
  • Note: The antenna will detach from the phone.
Aggiungi Commento
Using metal tweezers, unplug small white plug. Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
  • Using metal tweezers, unplug small white plug.
  • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
Aggiungi Commento
Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
  • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
  • The battery may be glued to the phone.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Clement Poisson
Membro da: 26/01/2010
24 Reputazione
14 Guide realizzate
Cal Poly, Team 13-23, Maness Winter 2010 Membro di Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,881
